Need opinion ASAP on replacing rear differential on C300 '08
My C300 '08 rear wheel with only 70k miles has been having noise coming from the back for a month and at first, I thought it was the wheel bearings so I got both replaced then the noise is still there...
Then my mechanic called and told me that the noise is actually from the bad rear differential.
He offers me 2 solutions
1.order a kit to fix it which will cost a bit more than the other choice but it will be a guaranteed. He said the kit will cost around $500 and with labor it should end up around $1k (he is a good friend of mine so he charges almost nothing)
2. To get a used one on ebay or junk yard, this way it is unsure when it will brake again but shouldn't one last a lifetime anyway? I found some on ebay for $350-500
Has any of you ever experienced this or known someone with this problem? I have been searching and forums and parts for quite sometime and thought that I might as well post one here!!
Thanks!!
