C300 battery removal problems
Old Oct 24, 2015 | 04:45 PM
hanoverdave's Avatar
C 300
I recently replaced the battery in my 2008 Mercedes C 300. Then the problems came. First problem. Engine light is on. Second, Air bag lite stays on. Third, a message on the dash that states, right front SRS malfunction. And last but certainly not the least. My engine fan runs on hi as soon as the vehicle is started. It stays on till you shut the car off. I took it to a garage that has done any work on the vehicle, all minor things. He then told me to take it to the dealer that he couldn't get into something or another. I am reluctant to take it to the MB dealer around here because I have heard nightmare stories of them over charging and dishonest business practices. Is there something else that can be done. Thank you so much
David
Old Oct 25, 2015 | 05:42 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
After 92 reads & no advice I thought I could offer a couple of thoughts :-
Often spurious electrical problems are caused by a weak battery. I wonder whether the battery is the correct one for the job , whether it has a fault (cell) & also whether it has been installed correctly ie terminals clean & tight ?.
The correct battery is 70 amp hours capacity & above & Absorbed Glass Mat (AGM) type.
SAMS can be damaged by incorrect installation ie the ignition key not turned off & removed & terminal arcing. Who did your installation? .
I would take it back to an auto electrician for battery testing & installation checking .
Interested to know how you go.
Old Oct 25, 2015 | 07:21 PM
Big Daddy's Avatar
C220 CDI SLK 200
I am afraid you will have to visit the dealer or independent repairer. they need to plug in their propriety star OBD 2 tester and reset the ECU to clear all the faults. here in Australia it costs $105
Old Oct 25, 2015 | 10:02 PM
Zozzle's Avatar
2013 c350
Are you serious? A battery terminal can't be undone without it costing $100? WTH?
Old Oct 26, 2015 | 01:41 AM
Big Daddy's Avatar
C220 CDI SLK 200
Have you tried a Norwegian reset? disconnect the battery for 30 mins and try again
Old Oct 26, 2015 | 07:10 PM
Zozzle's Avatar
2013 c350
Here are two vids on battery replacement without losing settings, parts 1 & 2 -
Time 6:35 on the 2nd vid shows you what to buy -
Amazon.com: SOLAR ESA30 OBD II Memory Saver Connector: Automotive Amazon.com: SOLAR ESA30 OBD II Memory Saver Connector: Automotive
The link takes you to the Canadian Amazon site. Look yours up on Amazon.com
$16.51
I ordered mine this morning.
