Wheel fitament
SL600
Wheel fitament
I have a 2011 C300 4matic sport and want to run these rims:
http://www.ebay.com/itm/141619594017?item=141619594017&viewitem=&vxp=mtr
Rear: 19x9.5
Bolt Pattern:
5x120
Offset:
Front: 37mm
Rear: 33mm
So here is what I understand the best fit would be:
Front
19x8.5
Tires:
225/35/19
Rear
19x9.5
Tires:
255/30/19
If I ran those rims with those tire sizes, would I experience any rub?
Rear: 19x9.5
Bolt Pattern:
5x120
Offset:
Front: 37mm
Rear: 33mm
Front
19x8.5
Tires:
225/35/19
Rear
19x9.5
Tires:
255/30/19
Will not work..
The Bolt Pattern that you have put up is for Bmw"5x120". Are
c-class Bolt Pattern: 5x112.
And with the offset/ tires size, you will rub.
SPONSOR/MBworld Guru
yes, those should work. Just make sure you get the right bolt pattern. And will want to make sure those are hub bore size, or if you'll need hub rings.
SL600
Thanks AZN Optics
https://n4sm.com/products/wheels/nic...10-matte-black
These are the ones I am looking at now with that offset, I dont know where to find if they are hub bore size though
Should be ok as the have a built in configuration so I'm sure will send you what will work with regards to the hub and bolt pattern.
