Trouble Shifting from R to D
A few days ago I backed up out of a parking spot, shifted into Drive, hit the gas, and nothing happened. The car didn't move, the engine didn't rev. I shifted into Neutral briefly then back to Drive, and everything was fine. I hoped it was just a fluke thing.
The same thing happened again this evening after backing up out of a parking spot. This time shifting into Neutral then back to Drive made no difference. I also noticed that the yellow exclamation point above the instrument cluster lit up. I ended up having to put the car in Park and shut it off. I started it back up again, and everything was fine. One other thing I've noticed is that both times this has happened, I've been unable to fully depress the brake pedal. It moves down slightly, then stops. I have noticed no other issues with the car. It seems fine.
I'll be calling my indy tomorrow morning to make an appt., but was hoping maybe someone could give me some idea of what might be wrong. I'm really hoping I'm not in for a costly repair, right after Christmas shopping.
They offered to squeeze me in today, so I dropped the car there this morning. I should have at least a diagnosis today, and will post back when I know what's going on.
I wonder if it's something to do with the braking system. Some cars cut the throttle if it thinks the brakes are engaged. I wish it did this with the parking brake. I've already backed out a couple times with it on. It only wars when in forward drive.
Was that the traction control light that you saw?
