Hey guys, just bought a 08 c300 sport and am completely in need of some help.
Issue#1- No Bass, It seems as if there is nothing coming from my subwoofer. I checked all of the speakers and they seem fine. Turned up the bass, made sure logic 7 was turned on and still there is barely any bass coming out of the subwoofer. Is there something I'm missing? ?
Issue#2- Passenger Seat Twists- My passenger seat well not go forward or backward. When i press it to move, one side moves and the other is just stuck and the whole seat just twists.
Issue #3- No auxiliary. I noticed i have the ipod integration kit, but i read that there should also be an aux input. Looked everywhere and I don't see it. Is there any way to just use bluetooth?
For starters did you purchase it private party or from a dealer? and any pics of your glove box will help were the auxiliary hookup would be located i could tell for you
Ok, so i bought it from a dealer. Issue#1 I think is fixed. The sub worked perfectly yesterday. Maybe it was an issue because it was really cold the other night when I was driving it (1 degree), is that a thing? ?
I also attached a pic of the glove box. Thanks
Yeah i dont see an auxillary input that should be there in my glove box i have two other wire setups ones for my auxillary you dont have that i dont use that receiver that you have it plugged in with and most likely i dont think the cold did anything
The aux input is a cable similar to the iPod integration one (has 3.5 mm aux input instead of iPod connector on the other end). It plugs in the receptacle to the left of the light in the glove box.
I can help solve your #3. There is a 3.5mm aux cable jack hidden inside your dash. Open your passenger door and pull the dash cover next to where the ipod cable starts outward (towards the right). It's not hard, a bit of force will do it. You should find a hidden cable jack in there. Just plug in a 3.5mm aux cable and you can either drill a small hole in the console interior (next to ipod cable) or just run the cable between some seams in the dash. You cannot use an ipod and aux cable at the same time.
Also for early w204's there is no Music over Bluetooth option. There is only voice calls over bluetooth. What I did was buy a VISEEO bluetooth dongle. Pair the VISEEO with your phone and you get bluetooth music via AUX.
