Engine light with P0017 code
Old Apr 1, 2016 | 08:46 AM
brendandoyle's Avatar
2011 C250 CGI
Engine light is on and code reads:
"P0017 Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor B"
Engine makes exactly this noise when starting:
Youtube comments suggest Exhaust Camshaft Activators? Any ideas?
Old Mar 18, 2018 | 07:28 PM
bigab24's Avatar
Mercedes Benz C250 Sedan 2012
2012 C250 Engine Noise - YouTube
Do you still have this issue? Just got this code on my vehicle as well accompanied with misfire.
Old Mar 18, 2018 | 07:32 PM
2011 C250 CGI
No resolved this a long time ago and has not had any issues since. Problem was the camshaft sprocket had to be replaced, apparently quite common with this model.
Old Mar 18, 2018 | 07:59 PM
bigab24's Avatar
Doesn't look good for me then I suppose since those are quite pricey from what I've heard.
Old Mar 18, 2018 | 08:05 PM
2011 C250 CGI
I called Merc and it was something like 300AUD for just a diagnose and 1800 for just the part without labour. I went to a independent Merc specialist and left it with them for a couple of weeks.. All up cost me 2500 for new sprocket, new timing chain, roadworthy certificate and labour.
Old Mar 18, 2018 | 09:20 PM
bigab24's Avatar
Thanks a lot for the advice! I do get the error code but I don't have such a loud startup, however, get that error code usually after having driven a bit usually in stop and go traffic.
Did you go with OEM parts? All I seem to be able to find online are aftermarket solutions.
