Adding paddle shifters to facelift w204?
However, re-reading this thread leaves me a little confused about what the function of the paddles actually is ... what I thought was, clicking the paddle gives you one shift up or down and then the transmission resumes normal automatic operation. Like if you wanted a sudden burst of acceleration to pass another car. But I see mention above of "true manual operation" which sounds like the only way to change gears would be to use the paddles each time? Or "gear limiter" which suggests once you upshift or downshift using a paddle, the car stays in that gear forever and doesn't shift again on its own? Can someone clarify?
