[Facelift] How to remove climate control unit
Old Apr 20, 2016 | 07:05 PM
Doitmyself's Avatar
C 350 Coupe AMG
Hey guys, i´m from Germany.
I want to replace the climate control unit on my coupe.
Its a facelift.
How do i remove the unit? Is there any tutorials, videos or something like that?
Old Apr 20, 2016 | 07:17 PM
Werkzeug's Avatar
463, 210, 211
Take a Teflon wedge or similar and pry on top and bottom of trim piece that surrounds the push button unit. Try to keep prying evenly. There are four compression clips at the back that hold it in place, if you pull too hard one direction it will break the clips. Once the trim piece is off the unit should simply pull out with wires exposed. Make sure the key is not in the ignition!
Old Apr 20, 2016 | 07:33 PM
Doitmyself's Avatar
C 350 Coupe AMG
You mean this unit?
Old Apr 20, 2016 | 10:00 PM
michail71's Avatar
2013 C250 Sport
BTW, what did you use to unclip the center AC vent? I've see a video where it looks like a special tool.
I wish I could get that Euro controller in Fahrenheit. We don't have the Zone button in the US.
Old Apr 21, 2016 | 12:25 PM
Werkzeug's Avatar
463, 210, 211
They are called kombi hooks. For that job though a simple 90 degree pick will work. You shine a light down the vent and inside on each side is a plastic tab that retains the vent assembly. With the kombi hooks you just insert and twist to get the tab to lift up. Then pull the vents out.
Old Nov 12, 2022 | 10:26 AM
WolfpackC63's Avatar
2012 C63 P31, 2023 GR Corolla CE
Sadly it's only that easy if you have a pre face lift model. 2012 forward, with the redesigned interior, nahhh. Much more involving.
