C300 Aux volume level
I've noticed that the volume level when playing music through my phone using an aux cable is quite low. I am driving a 2009 C300 using a Note 3. Other phones seem to be quite low also but may even be a bit louder than mine. I was wondering if anyone else has noticed this? Specifically with the C300s/Aux config. I haven't tried a new aux cable yet but I was wondering if there is anything that can be done or if anyone has seen this before?
My mother has a 2014 C250 that has a "aux volume booster" and it seems to play just fine even without the "boost".
Thanks all.
When switching from aux to radio there would be a sudden increase in volume and scare the crap out of me sometimes.
I have the Fiios E11 which is absolutely superb. It has amazing bass, clear sound and lasts many hours before needing a recharge. I probably recharge once every week, just to make sure I don't run out of juice. I am incredibly happy with this device.
I also have the Fiios E6, which is ok, but not that great. The bass isn't as nice and the sound a little more muddy, but I'm no audiophile and my speakers are the stock bose so it could be placebo. I use this as my back up solution.
I also bought a boostaroo amplifier. I bought this one purely because it doesn't run off batteries and will turn on and off with the car. So when I turn the car on, the boostaroo turns on. When I turn the car off, the boostaroo turns off. This makes it so much easier because I no longer have to remember or take the time to turn my amplifier on or off. It makes it as simple as plugging in the 3.5mm aux and being ready to play music.
The boostaroo has a serious issue for me though. I bought the USB version instead of the DC version. I use a DC to USB adapter to power it, and it works well for that. My problem involves static and distortion when driving. I believe that when I am driving at a variety of rpms/speeds, the alternator is fluctuating in power and this is causing variation in power output to the amplifier. Since the amplifier isn't powered by a steady power source such as a battery, these fluctuations cause the sound issues I am hearing. It bothers me greatly to have any kind of sound static or distortion so I am trying to find a solution. Boostaroo thankfully has a 90 money back gurantee, and I have only been a month into it. I'm going to try a power inverter next to see if that makes any difference.
If anyone would have any suggestions, I would appreciate it. I'm a biologist, not an electrical engineer
I found it helped me adjust the bass quit a bit, having audio 20 the bass was an issue now i get more out of my subwoofer and less out of the speakers.
try it out, it might help.
.Hi, just a quick question does your Fiios E11 charging while amplifying, I'm thinking about adding it to my glove box and I have usb charger over there too, will it play some music while charging, or is it one or another only?
Another solution is to purchase the excellent in-line PHP Sound Shocker, which correctly matches the input impedance and will boost the volume 12dB, requires no batteries, and is distortion free. Here is the link:
http://phpaudio.jigsy.com/products
I think I'll just order the Sound Shocker. Looks good and I've used something similar in my Audi A4 and it worked great.
Thanks Acapulco Bill!!
If you were able to think about my issue, it would be greatly appreciated.
I own a 2010 Mercedes B180 with Audio 20 sound system and built in Bluetooth telephone. The car also has an AUX port.
I want to stream music through the aux.
when I connect a Bluetooth receiver to the aux the music streaming works perfectly. However, when I make or receive a phone call the other person can hear me fine but intermittently their voice cuts out.
If I remove the cable from the aux socket, everything works fine.
Any help or advice would be greatly appreciated.
Thanks in advance.
Steve.
I was gifted recently a Bovee Viseeo Bluetooth adaptor that plugs into the iPod Integration Kit cable (which uses the Aux for audio feed). At the beginning I thought it worked fine. However, now I have my doubts too. My main complaints are:
1.- The Nav from my phone sounds too low in relation to the music streamed from Spotify, which used to have it's separate volume bar, but the latest updated Spotify does not.
2.- When I try and pause Spotify, the Bovee enthusiastically causes Spotify to play again.
3.- I think the Spotify reconnect malady forces me to push the steering wheel phone Receive button for about five seconds in order to accept a call.
Probably the same sort of issue is cutting out your phone communication, as your Bluetooth adaptor may be constantly trying to reconnect to your music app. I am unsure which Bluetooth device - the receiver in the Audio20 or the Bovee, is actually transmitting via Bluetooth during a phone call. This may be the source of the conflict.
It would be handy to post the specifics of your phone and Bluetooth adaptor manufacturer and model. I am anxious to solve this problem as although I receive few phone calls, the low relative volume of the Nav is a safety issue, and I am tempted to Unstall Spotify and load my smartphone with tunes and use a streaming app that has a volume control, and will successfully pause and not try and reconnect as this app would have to be be Bluetooth "illiterate", although this implies manual, rather than automatic, connection to Bluetooth.
Perhaps a separate Bluetooth Adaptor issues thread should be started?
Back to the matter at hand, I second the bluetooth adapter issue thread! I am soon going to be purchasing one!
I have tried 2 different Bluetooth devices. one does not have a microphone and can be used with or without the charging cable connected. I thought the issue was the microphone clashing with the inbuilt system. But it has the same issue as the first one I bought. This one also has issues with automatic reconnection.
Avantree LOW LATENCY Certified Bluetooth Receiver and Transmitter for tv | 2-in-1 https://www.amazon.co.uk/dp/B00LAZ6RTW/ref=cm_sw_r_cp_api_54zQxbTJ4W0SA
The other one has a built in microphone but I don't think that that is the issue. It connects perfectly after a call and when I get in the car I just press play either on my phone or on the little built in button.
It is perfect in every way except for the issue with the other persons voice cutting out on calls. I bought it in a local shop here in Sweden but it seems to be similar to this one
https://www.amazon.co.uk/dp/B01GJN6S0W/ref=cm_sw_r_cp_api_kaAQxb1E4N9RR
Now I am wondering if I can install a switch for the aux port. But if I have an extension cable plugged in but the switch is off, will it still cause the same problem because there is a jack plugged in even if it has no load?
Not sure if anyone else can comment on this but I believe it works off of conductivity, so it will still pick up the aux cord... Those are my findings with other AUX jacks, but I'm not 100% sure about the one in our cars.
