Rims for 2006 C class fit 2012 C Class?
Looking to purchase 19" sets of wheels from a 2006 C Class owner to put on my 2012 C class 300. Will they fit?? Is there anything I double check like spacers or tire size etc etc?
Thanks in advance.
I would be glad to help you with!
I can help get you fitted without worrying about any of the fitments and or spacers.
I will shoot you a PM now with some details
19x8.5 ET45 (front)
19x9.0 ET45 (rear) / Might be able to go as far as 9.5" width.
5x112 bolt pattern
Tires are going to be tricky as you will need to run some thin walls to avoid rubbing. Play around with this calculator to find a good size setup. You will probably need to go with 30 or 35 series tires to keep within the correct height range.
19x8.5 ET45 (front)
5x112 bolt pattern
Thanks for quick reply. Seller said 5x112 19x9.5 ET35 instead of ET45 like u suggest does that mean its a definate NO NO? As for tire size they are as follows
2 x 265/30z/R19
2 x 235/35z/R19
