Easy Entry/Exit Not working !
Old May 15, 2016 | 06:32 AM
nadhimali's Avatar
C 300
Exclamation Easy Entry/Exit Not working !
On my C300 - 2014 model Easy Entry/Exit Not working with an unidentified reasons.
1- The steering wheel is moving in all directions manually and by memory
2- The driver seat is moving in all directions manually and by memory
3- the Convenient setting on the cluster is stuck on Enabled and can't be disabled.
The only thing I tried till now is doing a DTC diagnosis and it gives the following lines
1- DTC Code 9EAF97 / Stored&Current / Easy entry/exit has a malfunction. The system function is restricted
2- Fault 01/ ESA "Driver" - Electric seat adjustment "Driver".
Any idea what does this mean
Old May 15, 2016 | 10:38 AM
michail71's Avatar
2013 C250 Sport
Did it ever work? I have a feeling the dealer would have a hard time diagnosing this one but at least you should have a warranty.
Old May 15, 2016 | 11:42 AM
Rocman8's Avatar
E55
Recently in an accident? Some models deactivate the feature and set that code if an impact was detected. It then will need coded back active at the dealership.
Old May 17, 2016 | 03:59 PM
nadhimali's Avatar
C 300
Yes, the car was hit from the front which deployed the steering wheel Airbag, Now everything fixed, however this feature is no longer working.
Old May 17, 2016 | 04:36 PM
Rocman8's Avatar
E55
Yeah, I just told you it has to be coded back active again at a dealership after an accident.
Old May 17, 2016 | 04:48 PM
nadhimali's Avatar
C 300
Thats great, i will have it coded tomorrow . Thank you for help
