w204 c320 cdi not cranking intermitent
c63 replica
w204 2009 not cranking intermitent
Please help if anyones had this fault - 2009 c320 cdi w204. at random sometimes once a week sometimes 2 times a day car wont crank - I get run flat indicator inoperative and traction control symbol inoperative see owners manual alternating on the dash. the other lights seem ok and the glow coil light doesnt come on either - turning the key further not cranking - also noticed the front fan is running quite fast when this happens. After some taking key out and closing doors and unlocking again it eventualy does crank - any ideas is this a common fault.
c63 replica
c63 replica
Strange symptoms can emerge when the battery is on the way out.
I suggest a battery load test .
Good luck.
Good luck.
c63 replica
Someone said its the supply going to the ecu or the ecu but im sure the supply to the ecu is from the front sam fuse box relays etc - so i took that out and took each relay out 1 or 2 of them had green corrosion on in the pins so cleaned them up and sprayed wd40 working them in and out.
I also took the rear sam unit a fuse box out in the boot which was actualy in a worse state loads of corrosion. cleaned up now - im at testing stage and for now the fault hasnt appeared yet. fingers crossed watch this space will report back if its still there,
Good thinking.
As a matter of interest, is your car normally garaged? Are you near the sea or run on salted roads? Any other reason for the corrosion?
You must not be in the USA as you call your luggage space "the boot" !
J.C.
J.C.
c63 replica
im in uk and no i dont live near sea - probably have a small leak in boot somewhere
W204 C320 C.D.I. not cranking Intermittent
The car has had a new battery and a mechanic has identified a potential battery drain.
Has anyone found a solution for this problem or knows where to start?
ma y thanks
