Need help with Rotiform wheel sizing on c300
I have a 2013 C300 4matic sedan and I have decided to replace the stock 17 inch wheels with 18 inch wheels however I'm having trouble deciding whether or not to get 18"x8.5" 45mm offset all around or a 18"x8.5" 45mm offset and 18"x9.5" 35mm offset staggered setup. The Rotiform SPF I want only come in 18"x8.5" 45mm offset or 18"x9.5" 35mm offset! Basically I want to know the best wheel and tire dimensions for a 18" setup on a C300!
45-54 offset is where you want to be.
I have 18's on my car I went with staggered just for the looks, 18x8.5 43 offset front and 18x9.5 53 offset rear
I just looked online the only option if you are dead set on those rims is a square set up 18"x8.5" 45mm offset all around.
you can add spacers to make it more flush on the rear to give it the staggered look, so it lines up closer to the fender.
check your manual it has the tire size for 18's you should get.
remember with 4 Matics you need the same tire brand and recommend sizing, if one tire blows lets say after 15,000km. your probably **** out of luck and need to buy 4 brand new tires just because of the 4 matic system.
(yes its a pain!)
(yes its a pain!)
pg 59 post 1458 is square set up with 45 offset, i know its a pain but look though as many posts and you'll find lots of pictures of 45 rear offset. It looks to be fine, i personally like to avoid spacers and just get a better offset rim.
I know the struggle to find rims it took me months to decide.
Not only is the bolt pattern apparently incorrect, but the tire sizes are off. The fronts aren't too far off, but those 255/30R-20 rears are about an inch taller than your stock tires, which will look stupid.
