Classe C (W204) Temperature Gauge Swing
Old Jul 24, 2016 | 08:48 AM
antodrm's Avatar
C Class W204 220CDI
Hi everybody, I'm Antonio from Italy
the issue with my W204 is that on an uphill road higway the temperature gauge swings up to 120°
Even if in winding roads for example Amalfi coast with much traffic the temperature remains normal.
I noticed also that after a long trip the cooling fan continues running.
I can post links of the videos I made from youtube
Thank you in advance
Old Jul 24, 2016 | 08:54 AM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
I'm assuming you have checked the coolant level...
Has the cooling system been checked/serviced recently? Possible failing thermostat?
Old Jul 24, 2016 | 02:42 PM
antodrm's Avatar
C Class W204 220CDI
Thank you for the prompt answer, the service told me also the thermostat works.
Do you any other suggestion?
Old Jul 25, 2016 | 08:52 AM
C300Sport's Avatar
If the thermostat is opening and you still have climbing temps while the engine is under load...
Water pump is failing?
Radiator and/or coolant passages in the engine are clogged and not allowing enough coolant to pass through. Could do a "flow test" on the radiator. Is the coolant nice and clean looking? If so, I would doubt it's a clogging issue...
Old Jul 28, 2016 | 07:50 AM
Josh.A.Hussey's Avatar
2017 C43 AMG, 2010 C350 4Matic, 9 Motorcycles
Check ECT. It reports the temp to the ECU
