Tire Pressure Light On
Old Sep 17, 2016 | 03:51 AM
C30013's Avatar
13 C300
My tire pressure light came on in the morning along with a message to check the tires. That message eventually went away, but the light is still on. There are currently no other messages, just the light. The pressures are correct in all tire, so what could be causing the light to be constantly illuminated?
Old Sep 17, 2016 | 12:14 PM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
Need to reset system.
Old Sep 17, 2016 | 01:41 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Yea mine was annoying af recently.
I just went in the settings and selected "set to current values"
Old Sep 18, 2016 | 01:38 AM
BacktoBC's Avatar
2012 C300 4matic
[QUOTE=dieseldoc;6917842]Need to reset system.[/QUOTE
Mine is doing the same thing. How do you reset the system? Thanks
Old Sep 18, 2016 | 02:17 AM
C30013's Avatar
13 C300
[QUOTE=BacktoBC;6918270]
Resetting the system worked for me.
In order to reset all you have to do is select "Tire Pressure" through the steering wheel controls, then press the down arrow, and confirm to set those values as your new reference values. Make sure your tires are properly inflated before doing this so that you don't reset with incorrect pressures.
Old Sep 18, 2016 | 10:39 PM
Josh.A.Hussey's Avatar
2017 C43 AMG, 2010 C350 4Matic, 9 Motorcycles
Any time you change tire pressure you should reset the system.
The low tire pressure system is based on delta's and the difference between what you have set the system at. Please reset the tire monitor for every time you change your running tire pressure on wheels.
