Calling M276 engine guru
Old Sep 19, 2016 | 06:20 PM
Isaac13's Avatar
2013 C350, 2013 GL450, 2018 G550 4x4^2
i have a leak on the driver side front timing cover. I would like to fix this myself but seem the power steering reservoir might be in the way of removing a bolt. Here are some pics. What do you think?? Any info would be greatly appreciated.
Old Sep 19, 2016 | 07:46 PM
kavadarci's Avatar
2012 C350 Edition 1
I would really like to know how to remove the engine cover\plenum.
In your case you might get better access once removed. Plus you shouldn't be tightening just one bolt.
Old Sep 19, 2016 | 09:12 PM
Isaac13's Avatar
Not sure what you mean by I shouldn't be tightening just one bolt. I am not . I am loosening them. There are like four or five but one of them seems like there might be something in the way..anyway not a problem because I have an idea on how to get it done. I will get it sealed.: just need some new oil and filter so I can take the filter out. Good time for an oil change anyway!!))))
Old Sep 20, 2016 | 12:37 AM
Isaac13's Avatar
Almost there
Old Sep 20, 2016 | 10:55 AM
Isaac13's Avatar
this is for you hope it helps you out
http://youtu.be/Xpeq2UWDmuk
Old Sep 20, 2016 | 02:47 PM
Isaac13's Avatar
It's actually pretty straight forward if you need to reseal you timing cover. Move stuff out of the way, unbolt eight bolts, pop off cover, reseal 1mm width around cover, install cover torque 5nm.
Old Sep 20, 2016 | 05:34 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Sorry I can't help
Old Sep 20, 2016 | 05:55 PM
Isaac13's Avatar
Oh not a prob, I got it handled. Resealed, curing now..
Old Sep 20, 2016 | 06:21 PM
Colin G's Avatar
2008 C-230 4Matic Sport
Nice work.
Old Jan 24, 2018 | 11:26 PM
tonycoco's Avatar
2013 GLK350 4MATIC
Did you have to clean the old seal off? What did you use to reseal?
