H&R sport spring
Subscribe
Sep 20, 2016 | 01:49 PM
Hi,
Finally installed all four springs (i doubt i want to do this again).
It is a lot of work
Front sits lower and even on each side but the back right is 2cm higher then the back left. this is significant.
I drove the car just around the block, not much and still sits the same.
All i can think of is the spring is not seated properly which i will be checking later.
If all checks well any suggestions? Should i just drive it and see what happens?
Wondering if anyone else experienced the same thing.
Thank you.
Reply 0
Sep 20, 2016 | 02:33 PM
Missing the pad?
Reply 0
Sep 20, 2016 | 03:35 PM
Just checked.
Bottom of the springs are in the grooves no problem.
I have the pads at the top and they look aligned.
I will drive it for a little bit and see what happens.
Reply 0
Subscribe
Currently Active Users (1)
