Dash speaker Buzzing
Old Sep 24, 2016 | 01:33 AM
pfarah77's Avatar
2008 SL550
Hey All,
Does anyone know how to access the front center speaker on a 1012 C250? Mine has started to fail (buzzing sound) and is quite annoying. I appreciate any help, thanks!
Old Sep 25, 2016 | 12:59 AM
andreb's Avatar
my11 c250 cdi avantgarde
the dash speaker fails due to exposure to the sun too much. i had the same problem in my w204 c250. i went to mercedes and they changed it for free and only had to pay for the part. approx 100$au. they used a fork shape tool and replaced it in 2 seconds.
best of luck
Old Sep 25, 2016 | 08:39 AM
pfarah77's Avatar
2008 SL550
So I guess the dash doesn't have to come apart, great!! Now, where to insert that forked pry tool without screwing up the finish...
Thanks Andre!
Old Oct 8, 2016 | 06:47 PM
pfarah77's Avatar
2008 SL550
Ok, so I tackled the speaker replacement this afternoon. Not a bad job after all just keep in mind that plastic is all around you.
1. Simply pry the left hand corner (closest to you) with a plastic body clip removal tool. Gently move the tool across the panel until all four metal retaining clips pop off.
2. There is an electrical connector that is squeezed to remove (releasing small tab). Grab the panel with both hands and gently, but firmly, pull it toward you to release the plastic tabs from the dash near the windshield.
3. The speaker is secured by two plastic tabs built into the speaker frame. Simply grasp the speaker and pull straight up and disconnect the speaker wire connector.
This is a five minute job once you perform it once.
Also, please note which speaker to order. I purchased (#1728200602) which is for the Audio 20 system whereas I have the HK system which calls for (#1728200702) (who knew? The dealer certainly didn't). Both speakers have the same dimensions but I'm assuming there are dynamic audio differences. At least the buzzing is gone so I'll wait it out and replace with the proper speaker at some point, now that I know what I'm doing...
Attached Thumbnails Dash speaker Buzzing-sp1.jpg   Dash speaker Buzzing-sp2.jpg   Dash speaker Buzzing-sp4.jpg   Dash speaker Buzzing-sp7.jpg   Dash speaker Buzzing-sp5.jpg
Old Oct 9, 2016 | 06:44 PM
andreb's Avatar
great!!
as this is a common problem with w204 dash speakers from the sun exposure. Fantastic description. top job!
Old Oct 10, 2016 | 07:39 PM
pfarah77's Avatar
2008 SL550
Thanks.
