Front Left Lights out.
I've had a message for some time to check left parking lamp, which I let go on for a while then3 days after getting an oil change with a non-dealer location my check left low beam light message came on. I purchased a H7 bulb, but accidentally pulled out the wrong H7 bulb and placed the new H7 bulb in that plug, the new bulb didn't work. I then realized that the low beam lamp was next to the one I was replacing, so I place the bulb in the correct place and now neither lights come on. The bulbs are still good. could this be a fuse issue? If so which fuse should I be looking for to replace? Thank you in advance
Surprisingly, the interactive owners manual does not have a chart for which fuses are where. It mentions a fuse panel on the drivers side of the dashboard, in the engine compartment, and in the trunk. There is a fuse allocation chart in the tool kit in the trunk.
