help!!!
Old Nov 13, 2016 | 03:36 PM
romeo626's Avatar
2012 c250 sport
help!!!
i recently encountered a DIY gone wrong!
I was setting up to do a simple oil change on my 2012 c250 when everything came crashing down..literally haha.
i was jacking the car up from the front jacking point in order to place the car on jack stands. suddenly the plastic that sits on the crossmember snaps and causes my jack to slip and smash through the under covers...sadly my radiator and fan assembly were crushed completely.
now, I am seeking for a replacement radiator and fan if anyone has anything lying around and wants to sell. I know it's a long shot but the stealership is charging an arm and leg for both parts.
i am located in Los Angeles 626 area. please pm me with any leads or help.
Thank you all!
Old Nov 13, 2016 | 06:43 PM
M~Factor's Avatar
2017 AMG GT, 2015 ML350, 2013 C300
Very lucky you weren't underneath when it happened! The car gods are watching over you!!!
Old Nov 13, 2016 | 06:56 PM
pfarah77's Avatar
2008 SL550
Ouch...!
Did you use that special jack insert? It appears that most newer cars these day have one. Good luck on the search, however; you may want to search some bone yards.
Old Nov 14, 2016 | 07:12 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
I did not know there was a jacking point under the radiator. My 4 dedicated jacking points are at the side of the vehicle.
Old Nov 14, 2016 | 09:05 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Same ^^^^^^^
Old Nov 14, 2016 | 09:30 PM
twowheelin's Avatar
2014 C250
Here it is, front and center of the car. About a foot behind the bumper on the cross member.
Lift here, then put jack stands on the side support points. (Just make sure your jack can't slide off of the jack point. )
