What is Factory Fill Power Steering Fluid w204 c300 2010
Old Dec 4, 2016 | 08:35 PM
VegasWhoa's Avatar
2010 C300 4Matic Lux W204
Looking to find out what the factory fill is on a 2010 C300 Production date 10/2009.
I have 97k miles on it and after looking thru the service history,(all done at MB Dealership prior to 67k rest was myself), I don't see anything stating PSF was flushed and changed.
I ask because, if MB 236.3 PSF Gear Oil is factory filled, I obviously don't want to mix with the newer/better 345 Hydraulic Oil.
I did have to add some (30ml) as the reservoir was low. I added Febi Gear Oil MB 236.3 Dexron II but want to flush this ASAP if I shouldn't have.
Attached is a picture of what I sucked out today and added more gear oil to get some cleaner stuff in there.
One thing I did notice in the picture attached is a possibility of oil separation? Is the bottom more brown or honey'd and the newer psf gear oil on top?
Attached Thumbnails What is Factory Fill Power Steering Fluid w204 c300 2010-img_0006.jpg
Old Feb 28, 2017 | 02:31 PM
GoSuckMyTites's Avatar
2010 Mercedes-Benz C350 4Matic
I was using Pentosin CHF 11 S Hydraulic Fluid following the 345.0 specification.
I wonder if you can help me out. I was trying to suck the PSF out as much as I can, the first I was using the turkey buster as you did, then I reach the horizontal baffle just below the filling cap so that I can't get more than like 5ml out.
Any comments on getting as much as possible?
Thanks,
Old Feb 28, 2017 | 04:22 PM
Colin G's Avatar
2008 C-230 4Matic Sport
Buy this pump off amazon. I use it for oil changes and it sucked out my PS fluid when I had to remove my power steering reservoir.
Amazon Amazon
Old Feb 28, 2017 | 04:34 PM
https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
Thanks Colin!
I will definitely check it out and hopefully this time I can get more out.
Old Feb 28, 2017 | 04:36 PM
Colin G's Avatar
Originally Posted by GoSuckMyTites
Thanks Colin!
I had to really jam the tube in there, move it around to find low spots ect but I got quite a bit out.
It works great and if it ever blows up, the pump is cheap enough to buy another.
Old Feb 28, 2017 | 04:46 PM
Thank you so much for the tip! Yeah, I was a bit worried about how to get more fluid out since the horizontal baffle is blocking the way.
