2008 C350 Blower Motor Replaced But Still Not Working
Old Dec 10, 2016 | 04:26 PM
robversc's Avatar
c350
Hoping someone can help.
I have a 2008 C350 where the blower motor stopped working. I was able to manually push it to start several times, but no longer.
I ordered and replaced the blower motor with part A 204 820 02 08. When removing the old blower motor, a significant amount of water came out, so I thought I had correctly identified the issue.
However, once I had everything put back together, the blower motor did not turn. With the HVAC system switched on, I can feel heat radiating from the vents, but no air movement.
I reviewed the fuse diagram, but only can identify the general AC / Heater fuse (#12). There does not appear to be a fuse isolated to this blower motor.
Any thoughts on next steps. Replace the Blower Motor Regulator?
Thanks in advance.
