We're Building a W204 C300 Race Car!
Old 01-26-2017, 09:50 PM
  #51
Former Vendor of MBWorld
FCPEuro's Avatar
Mercedes
This week we took a break from the build to have the car wrapped in our livery along with our partner logos. This year we are working with two great partners including ROWE and Rein Automotive. Part of our partnership with them involves the incorporation of their logos with our livery. These photos were just released to the company and I wanted to make sure that I had them posted here as soon as I could. Check it out:
Coming up this week we have a lot of work left to do. Primarily we need to retorque all suspension components to the proper specification, reinstall all underpanels and fender liners, fab the rest of the exhaust, install rear window and windshield, clean up inside of the car and wiring, install adjustable front sway bar links, install adjustable rear camber arms. Our schedule and plan is to have this car ready to roll out to Atlanta as early as 2/6 if weather is a concern.
intrdrgn (01-27-2017)
Old 01-27-2017, 01:59 PM
  #52
intrdrgn's Avatar
2010 Mercedes C300 Sport
Looks real good Quick glance thought you guys were going Five-O!
Old 01-27-2017, 02:09 PM
  #53
Just204's Avatar
Mercedes w204 4matic sport
Looks great! Though, after you guys button this bad boy up make sure your driver gets good seat time so he gets used to it and you can work out the hadleing quirks. The driver mod is the most important. Did you guys put in a shift light? I'd put in lexan for the front/back windshields to reduce weight more 😉.
Old 01-28-2017, 06:07 PM
  #54
FCPEuro's Avatar
Mercedes
Well, this particular shop does wrap police cars which I'm sure you probably noticed in photo 1 and 2.
Excellent suggestion. We're not going to have much opportunity to do testing local so the first shake down is going to happen at Road Atlanta on 2/9. The great news is all three drivers are going to get an opportunity to drive it on 2/9 all day and 2/10 in the morning before qualifying.
For the moment, we're putting the OE glass back in because of time. But we will most likely use lexan for the second race of the year at Watkins Glen. Just running out of time to finalize it for Road Atlanta. As it is, we basically built this car in 2-2.5 months.
No shift light yet, but that is on the list. We're looking to use a different instrument display and ditch the stock Merc unit. TO do so we'll have to figure out the electronic side of it.
Old 01-28-2017, 06:09 PM
  #55
FCPEuro's Avatar
Mercedes
We were going to do an official unveil on Monday morning but I'm going to give you guys a sneak peak on the final result. Both the trailer and C300 have been wrapped up (no pun intended).
The following 3 users liked this post by FCPEuro:
BlackRaizo (02-03-2017), dannyboy42670 (06-10-2017), intrdrgn (01-29-2017)
Old 01-28-2017, 11:16 PM
  #56
Just204's Avatar
To help with figuring alignment aspects. Get an infrared temp gun, literally as soon as a "real" practice run at race speeds is done take the temps of the tires on the tires across the tread. That can help in figuring camber for cornering and inflation psi, try to get it even by adjusting the psi in small amounts and then work on the alignment when that's dialed in. And yes, this was done really fast !!
Old 01-28-2017, 11:34 PM
  #57
Just204's Avatar
Actually, if you want I'd be happy to share things I know on alignment aspects and can dig up some good resources to help if your interested. You can pm me a contact number if you'd be interested, no offense taken if your not interested .
Old 01-30-2017, 07:16 PM
  #58
Crimzon's Avatar
2010 M_B C300 ... Wife drives a 2007 GL450
Awesome looking .... Can't wait to hear of the results
Old 02-02-2017, 01:04 PM
  #59
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Looks good!
lightweight battery?
Old 02-02-2017, 03:06 PM
  #60
FCPEuro's Avatar
Mercedes
That's pretty good info. We weren't doing that last year with the E30 but the car is significantly lighter than this C300 is. We're going to have to try that one.
Absolutely, more than happy to look into the information. My contact is gareth1@fcpeuro.com.
Originally Posted by Adi-Benz
Looks good!
Yes, we put a lightweight battery in the trunk. About to post some new photos.
Old 02-02-2017, 04:16 PM
  #61
FCPEuro's Avatar
Mercedes
This may be the last post I'll be able to put out there on this car before the race. We've been in full crunch mode here figuring out the last pieces of the car before we head out to Atlanta. Currently we're working on the kill switch and some other electronics in the car but the good news is the car as a whole is almost ready to roll out.
The car came back to our facility on Monday (1/30) and first thing in the morning and we had the OE glass reinstalled. While we plan on replacing this eventually with Lexan this had to do for now:
Monday afternoon we also did a reveal to the rest of the company so everyone could see it in person:
On Monday night we applied Laminx to the headlights, fabbed up the rest of the exhaust, installed rear camber arms, and front adjustable sway bar links (couldn't get photo's of everything but it's there). We also figured out how to route the brake ducts and the hole where the AC compressor used to be worked perfectly for routing the driver side duct. We will be modifying the factory C63AMG backing plates to accept these cooling ducts.
We had issues with belt squeaking and it seems we have been able to resolve the issue by running a slightly longer belt. We originally a factory belt length for W204 C300's without AC (yes, they exist apparently). However there was a ton of tension on the smooth idler with the belt installed and noise could be heard. We put a slightly larger belt on and it seems the problem has resolved itself.
We also machined the rear adjusters down and notched the spring perches as well to get additional adjustability in the rear. We were able to get the desired ride height through this modification. I will get photos of this when I can.
Old 02-02-2017, 07:58 PM
  #62
jumph4x's Avatar
W210 DRFT BNZ
Killen it.
Old 02-08-2017, 02:21 PM
  #63
IB Staff
MBWorld Editor's Avatar
Front page news!
Front page news indeed! Good luck this weekend!
https://mbworld.org/articles/w204-c3...truly-awesome/
Old 02-08-2017, 02:58 PM
  #64
ROLLNNN's Avatar
2005 CLK320 Vert & 2005 CLK55 AMG
love this! sweet build guys....
Old 02-08-2017, 04:21 PM
  #65
Ders's Avatar
2005 E55 AMG
Holy crap this thing came together quick. Well done.
Old 02-08-2017, 04:43 PM
  #66
shotgun_banjo's Avatar
'13 GLK350 4matic,'09 C300 4matic,'15 GLA250,'07 Honda Odyssey, '18 GLE 43
I'll take that car than any C63 anytime or even any exotic. Like the idea that it is built to race but still sips gas like a regular c300. I wish all c-class cars are like that.
Old 02-08-2017, 11:23 PM
  #67
Crimzon's Avatar
Awesome build guys ..... Love it
Old 02-09-2017, 02:20 PM
  #68
romeo291's Avatar
W204
What kind of adjustable sway bar end links did you guys use on the front?
Old 02-10-2017, 06:15 AM
  #69
dipdip19's Avatar
Mercedes Benz W204 C350
why c300 not c63 ?
Old 02-10-2017, 07:04 AM
  #70
BlackRaizo's Avatar
2014 C250 Sport, 2013 ML350
Originally Posted by dipdip19
why c300 not c63 ?
Originally Posted by fcpeuro
we could have gone C63 but we were keeping in mind operating costs and the how the car would be classed. AER has 5 separate classes and some of the most competitive classes are cars in the low to mid 200 horsepower range.
pozi240 (02-10-2017)
Old 02-10-2017, 09:18 AM
  #71
romeo291's Avatar
W204
Originally Posted by BlackRaizo
lol, you're an enabler of lazy people who don't read.
The following 2 users liked this post by romeo291:
BlackRaizo (02-10-2017), pozi240 (02-10-2017)
Old 02-10-2017, 02:18 PM
  #72
BlackRaizo's Avatar
I've been on forums since 2006, mostly sport bikes, and people really have a hard time understanding how forums and the interwebz works.
Sometimes it's easier to just post the answer than saying, "Did you read the thread"?
We need more race car pics!
Old 02-10-2017, 02:29 PM
  #73
dipdip19's Avatar
ive read but have missed that comment. so im sorry mate
Old 02-10-2017, 03:47 PM
  #74
romeo291's Avatar
W204
No worries. If you've read enough threads on this forum, you should know to expect someone to always say "why not C63" when it comes to anything performance related.
Old 02-11-2017, 08:39 PM
  #75
FCPEuro's Avatar
Mercedes
We used a Mustang S197 adjustable link from Whiteline, part number KLC169.
We also ended the day first in class!! We've got a live feed on our YouTube channel located here, it was pretty exciting and you guys can view it here:
https://www.youtube.com/user/fcpgroton/videos
--Kyle
The following 2 users liked this post by FCPEuro:
BlackRaizo (02-12-2017), romeo291 (02-12-2017)
Quick Reply: We're Building a W204 C300 Race Car!
