Fumoto Valve F316L
2017 AMG GT, 2015 ML350, 2013 C300
Fumoto Valve F316L
I bought the below Fumoto oil drain valve for my '13 C300 but it didn't quite fit. It seems to need an additional extension since the valve does not sit flush against the oil pan. Has anyone run with the same problem?
F316L: M14-1.5 FUMOTO ENGINE OIL DRAIN VALVE W/ L NIPPLE
did u use the washer that came with it. I bought one of those valves but decided against its use because after screwing in to oil pan it seemed like the screw part goes to deep into pan and I worried about it not draining all the oil. I tested one on my sons toyota and drained the oil with valve in, after oil stopped I removed the valve and more oil came out of the pan. just my opinion
M~Factor (01-30-2017)
Factory ordered 2012 MB C350 w/Dynamic Handling Package
FWIW, I understand why one would want to install this valve, however the easiest way would be to vacuum the oil out using an extractor and leaving the drain plug alone.
All my cars and trucks I ever owned had one, including my ML350. I'm an old school kind of guy and would like the same for my C300. Having said that I think its time to try the extraction method.
Has anyone tried the extraction method and remove the drain valve if more comes out at the bottom?
