2008 c300 wont start but battery ok-Possible Fuses??
Old Feb 9, 2017 | 12:45 PM
asmith5rgv's Avatar
2008 c300
Good morning all. I have a 2008 C300 that will not start. Battery ok and lights work. Thinking it might be a fuse. #6,7,19,27 are ok but my #9 was fried. I replaced. I did not go thru every fuse in all 3 boxes yet. Is there another fuse that would keep it from starting. Checking all the easy stuff first. Thanks in advance.
Alan
Old Feb 9, 2017 | 08:30 PM
cvx5832's Avatar
325Ci, 325Cic, C300
Alan
Do you hear the steering lock disengaging/engaging when you insert/remove the key?
Old Feb 10, 2017 | 11:08 AM
Alfadude's Avatar
2012 C300 4Matic
Does it crank and not start when you turn the key or does it not crank at all?
How did you determine the battery is good? With how sensitive cars are today with all the electronics there might not be enough juice to start it even though the lights come on. If it was running perfectly fine the last time you used it and then all of a sudden it won't start it could be the battery.
Old Feb 12, 2017 | 07:58 PM
95_993's Avatar
G63
EIS failure?
