2009 C350 TPMS Issue
Hey guys,
My car seems to be having an issue with the TPMS. I checked my psi and made sure they were all correct and then reset it via the gauge cluster. It blinked several times and continues blinking. It seems like I possibly have a bad TPMS sensor in one of the wheels. Is there a way to determine which one is the bad one myself and/or does anyone have any idea as to how to fix my issue? I was not sure if the Engineering Menu/Screen has a read out of PSI and I can determine it that way. Any info/advice would be greatly appreciated.
I took the car to the dealership after I noticed a metal on metal sound at low speeds. I took both of the wheels off and determined that something was banging around inside the wheel, most likely a Tire Pressure Monitor Sensor. They replaced the sensor at no charge and it seems like everything is working correctly now. This was about 6 days ago. I've been driving it since then and put a couple hundred miles on and everything seems to be working correctly.
