C200K rotor replacement?? easy help
Old Mar 19, 2017 | 05:50 PM
mromiti's Avatar
c200 kompressor 2008
Hi guys, I need to replace my 2008 C200K break pads, but I'm not sure if disks need replacing. Even though mileage is relatively low (52.000 km/32.000m) I don't want to waste new pads...
The thing is I couldn't find anything written on the rotors regarding minimum thickness... Tinkering around I found these markings on the pictures which are the only thing that could be a wear sign.
If it really is, then I still have 3mm left, meaning I probably don't have to get new rotor disks. Can anybody help???
Second question: any problem with changing pads without turning disks?
Internal thickness is about 26mm
Thanks a lot!!!
Attached Thumbnails C200K rotor replacement?? easy help-75a84bd5-a331-4a90-893e-445b6d873268.jpg   C200K rotor replacement?? easy help-fc4f4f30-ef22-4158-aaeb-34c1e31159bf.jpg
