Vibration And Idle problem
Old Mar 25, 2017 | 08:31 AM
JasminChicago30's Avatar
2008 Mercedes c300 4Matic
08 c300, has this rough noice when is on af low idle, and when is in the park and neutral the idle works fine, but when i put it in drive the rpm goes down alittle and vibrates, same thing when i come to a stop the car vibrates and the rpm goes down thats when the vibration happens, i noticed it when is more colder outside it vibrates more than on a nice day, any suggestions? Could that be the Engine mounts?
Old Mar 25, 2017 | 08:29 PM
chrisridebike8's Avatar
'10 C63
Sounds like motor mounts.
Old Mar 25, 2017 | 11:17 PM
timlippold's Avatar
2008 C300 Sport
Could be motor mounts or front axle. Mine does it but not bad enough to warrant an investment.
Old Jul 5, 2024 | 05:08 PM
retna7's Avatar
2000 E430 Sport
M273 engine misfires at idle.
Replaced:
Ignition Coils 2019
Spark Plugs 2019
Camshaft Adjusters 2022
Fuel Pump 2022
Fuel Filter 2022
Intake Manifold Gasket 2022
Decarboned Intake 2022
Fuel Injectors 2022
Knock Sensors 2022
PCV Vent Valve 2022
Motor Mounts 2022
Transmission Mount 2022
Air Pump Control Valves 2024
Oil Centrifuge (Drip Pan) 2024
PCV Oil Separator 2024
No codes and drives well outside idle with a cold start. Idle seems fine once warm.
Cleaned the MAF but may need to be replaced.
Could be OE Tune affecting timing so I'll be contacting customer service for removal instructions.
Have no idea what else it could be:
Cold start after a few days:
Old Aug 11, 2024 | 10:44 PM
vivekchan's Avatar
E350 CDI 2010
Is it sorted now? I have the same issue E350CDI 2010
Replaced:
Ignition Coils 2019
Spark Plugs 2019
Fuel Pump 2022
Fuel Filter 2022
Fuel Injectors 2022
Knock Sensors 2022
PCV Vent Valve 2022
Motor Mounts 2022
https://youtu.be/08uo6PsvpBc
Old Jul 22, 2025 | 04:29 PM
scoodidabop's Avatar
2011 w212 wagon
I'm gonna revive this thread to chime in with my newly acquired w212 wagon having the same vibration issues. Did anyone ever solve this? Would love to know if there's a solution! Judging by the number of people raising their hands here I'd say it's not a rare issue.
