W204 Gasoline - battery type
Old Apr 9, 2017 | 09:21 PM
superangrypenguin's Avatar
A car
What sort of battery is the W204 OEM (gasoline models)?
Conventional Flooded Acid, AGM Flat Plate, AGM Spiral Wound or Gel Cell batteries.
What's the OEM CCA? 760? Thank you!
Old Apr 9, 2017 | 10:48 PM
omega48er's Avatar
2009 clk-350 (Black) AMG, 2009 clk-550 (Pewter) AMG
I believe the stock is the flooded acid... Not sure on the CCA but the group is H7
In any case you should swap it with an AGM battery.
I swapped one in my CLK550 after the stock one died and never had an issue with it even after the car sits for a month of bot being used.
Old Apr 10, 2017 | 12:02 AM
c300white's Avatar
2008 C300
My varta lead acid was good after 8.5 years still - replaced it with Bosch h7 at pep boys anyway. I agree - go with agm if you are going to leave car standing around a lot ....
Old Apr 10, 2017 | 01:23 PM
PelicanParts.com's Avatar
SPONSOR
If you need help and want a DIY for its replacement be sure to check out our article here: http://www.pelicanparts.com/techarti...eplacement.htm.
