HELP W204 C220 NOISE.
Back to a Mercedes now after coming from a 320d Touring and a W202 before that.
Problem is i have purchased a 61 plate C220 diesel @ 100k, the car is immaculate but seems really noisy to an extent it sounds like a 6.3 AMG.
At idle its normal, pull away seems really noisy then seems normal around 40mph, kick down and it sounds like noisy again, sought of like its running on 3 cylinders.
Can anyone point me in the right direction where to start looking??
Only had it a week
Thanks in advance.
There is no loss of power, seems very fast, no error lights up.
Its really annoying, has anyone else had this problem? or can point in the right direction, cound it be vibrations from the gearbox.
I tried to get a recording but you cannot really hear it.
My son could here the noise driving the car but i could not hear any noise outside, there a local Mercedes indy near me i will go there in the morning.
To check exhaust for leaks just place a rag over exhaust for a few seconds to create back-pressure . A hiss noise will tell you you have a leak.
Do you think it could be a pulley, it really seems like its running on 3 cylinders if you no what i mean, but there is no loss of power.
I suggest you check another similar car to compare.
Will post back conclusions
Thanks.
