Mercedes GLK 220 CDI 2009 DTC U118200 & U102700
I have a problem in GLK 220 CDi 2009 with a strange problem, turn key in ignition have all light in dash on and car does not crank, after turning off the ignition off the dash still on all the light on it block that i must disconnect battery to be off again, i have in display error of ESP with diagnostic, i have not communication with engine ECU, ABS/ESP, Automatic gear box, so i can communicate just with Airbag and the front SAM gateway and in that module gateway have two DTC's:
U118200: The chassis CAN Network management is unstable.
U102700: Chassis Can Bus OFF
I have replace both EZS and ESL no change, what can be the problem? Is it the gateway or the wiring?
If the wiring i will need the diagram, here is the VIN of that car: WDC2049841F371473
Please help.
