w204 AC No Cold Air
Old May 31, 2017 | 05:34 PM
Josh13's Avatar
Mercedes Benz C-300
w204 AC No Cold Air
Recently m 2009 c-300 with 98k miles, made a whining noise while driving and then presented me with no cold air whatsoever. Figured at first it was a low refrigerant problem, but the low pressure valve doesn't seem to draw in any additional refrigerant. It doesn't sound like the clutch is engaging either when I hit the ac/on button. Any insight as to what the problem may be?
Old Jun 1, 2017 | 08:17 AM
superangrypenguin's Avatar
A car
Compressor is probably toast. Our clutches are variable though. It's not a case of on or off... So I'm not sure if you can in fact hear it.
Old Jun 1, 2017 | 06:23 PM
Josh13's Avatar
Mercedes Benz C-300
Yeah my guess is the compressor may be toast or the control valve on the compressor may have failed. Thanks for the clarification. I just found out the compressor uses a swatch plate, hence the variable valve ac compressor is always turning. Are there any possible diagnosis I can do myself before selling my soul to the stealership or an indy shop?
Maybe a test to measure levels of refrigerant? Would a w204 ac compressor give out with low levels of refrigerant or insufficient lubrication?
Old Jun 1, 2017 | 10:57 PM
A car
I try and as factual as I can be on these forums, and this is one of those times when I say that I'm merely guessing as I'm going a bit out of my element here.
1) I don't believe there are any possible diagnosis that you can do yourself, short of maybe pulling a code from the OBD2 port - which I'm fairly certain will have no codes for this issue
2) There is no way to test whether or not there is indeed enough refrigerant.
If I were you, I'd go and visit an indy shop and have them take a look. AC systems are pretty much closed and there's not much anyone can do when these systems go awry, unfortunately.
Old Jul 19, 2020 | 06:21 PM
Spencer Gall's Avatar
2013 W204 C300
Hey, did you ever find the issue or get it fixed? What was done? Same thing just happened to me, driving, hear a whistle/leaking noise and then no more AC. Any info would help.
Thanks.
