W204 NEED HELP
Old Jun 14, 2017 | 02:26 PM
jtauto's Avatar
W204 C200K
W204 NEED HELP
Hi I have recently replaced original new parts for my W204 C200K
1) front & rear shock absorber (incl. mounting, stopper & dust cover)
2) upper & lower arm + bushing
3) engine & gearbox mounting
4) 4 x Michelin Pilot Sport 4 tires
However my car still feel very "bumpy" & "shaky" when in motion on uneven road. What else could be the cause of it???
Desperately need some advice.....TQVM
J.T.
Old Jun 14, 2017 | 02:50 PM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
What size wheels and tires do you have?
Old Jun 14, 2017 | 02:54 PM
jtauto's Avatar
W204 C200K
stock 225 45 R17
Old Jun 14, 2017 | 04:01 PM
dieseldoc's Avatar
Originally Posted by jtauto
stock 225 45 R17
Are your wheels balanced properly or is one of your new tires out of round.
Old Jun 14, 2017 | 04:12 PM
jtauto's Avatar
W204 C200K
yes they are balanced before installing
Old Jun 14, 2017 | 04:27 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Tyre pressures too high?. Is the ride just rough & hard over uneven surfaces or does it sway around?
Old Jun 14, 2017 | 06:01 PM
jtauto's Avatar
W204 C200K
Tyre pressure is normal
The ride is rough and hard only over uneven road
When you mentioned sway does it mean the car body "rock" along the horizontal,left right and front back position
Old Jun 15, 2017 | 05:07 PM
Carsy's Avatar
Are they sports shockers ie giving a harder ride. 17" tyres compared with 16" don't help.You may not be "used" to the new components.
Sway, Yes, unusual body movement on the suspension.
Were the arm bushes tightened when the suspension was in the normal position off the jacks?
I would drive a similar car somewhere (dealer) to compare.
Good luck.
Old Jun 15, 2017 | 08:37 PM
OrientBlau's Avatar
2011 C300 4MATIC
J.T.
I think its your sport suspension and you're not used to it. I have the Luxury model and just had new shocks and struts replaced. The car still rides poorly over bumps or rough roads. Sport is much stiffer than Luxury, and Lux still feels bumpy.
Old Jun 15, 2017 | 09:32 PM
dieseldoc's Avatar
I would agree that it is your sport suspension. my 204 is definitely not compliant on rough surfaces. I would make sure everything that was replaced was put back together properly. You can also have issues with bumps/shakes if you have a bent wheel even if they balanced the tires.
Old Jun 16, 2017 | 01:27 AM
NZ-Merc's Avatar
W204 C200, BMW E30 M3, 1980Gt Mini, Toyota Corona, KTM 200 EXC.
Perhaps you are noticing it now due the new shocks are back stiff like they should be when new and you’re old ones were shot and made the ride soft.
Old Jun 27, 2017 | 09:00 AM
jtauto's Avatar
W204 C200K
Thank you all for sharing.
I understood that the absorber are new however it seems rather too hard and makes the driving very uncomfortable and not enjoyable as compared previously before i changed these parts.
Old Jun 27, 2017 | 09:11 AM
jtauto's Avatar
W204 C200K
Mine is avant-garde model does it originally comes with sports shocks?
Old Jun 27, 2017 | 10:01 AM
superangrypenguin's Avatar
A car
Try running 28psi in the front and 33 psi in the rear. This is supported by Mercedes (I have posted a PDF on this in the past). This helped my ride tremendously.
Old Jun 28, 2017 | 12:18 PM
jtauto's Avatar
W204 C200K
actually i have done that....may do a proper alignment again...don't know whether it will help
