air mass sensor
Old Jun 23, 2017 | 07:37 AM
hashudada's Avatar
c 180
air mass sensor
i have a w 203 c 180 2001 modle , and it shows engine light , when i got it checked with someone the codes show air mass sensor error, i need suggestion should i buy a new sensor or should i get the old one cleaned first and see if it works , or i want to know does it works after cleaning with the sensor cleaner ?
Old Jun 25, 2017 | 02:44 PM
IGB's Avatar
IGB
'08 C300 MM Pano
If the sensor element is dirty or contaminated, yes, the cleaner works. And you can only find out if you try! Otherwise you may have to replace it
