Service B reminder will not reset
Old 07-04-2017, 11:41 AM
dennish's Avatar
1992 MB 190E, 2016 MB C300
I followed the YouTube video, but the ASSYST PLUS menu does not come up after step 2 (pushing the call button and OK button). I can access the ASSYST button by manipulating the buttons, but then the appropriate menu to delete will not come up. It returns to the mileage/trip display.. Any ideas on what is going on and a resiolution to delete the service B reminder?
Old 07-04-2017, 01:04 PM
Colin G's Avatar
2008 C-230 4Matic Sport
Hit the buttons at almost the exact same time. Just a millisecond delay or it will not work.
Old 07-04-2017, 05:03 PM
michail71's Avatar
2013 C250 Sport
Are you sure it was on the odometer? It will not work unless you see the odometer on the screen. Most of the videos kind of gloss that one over or just say to cycle to the trip menu.
Old 07-05-2017, 11:52 AM
dennish's Avatar
Still no luck after repeated tries following above advice. Wondering if anyone else had this problem. Is this a dealer fix. Also, I'm wondering if maybe my OE tune could be the culprit. I've had no other electronic glitches and the other steering wheel buttons work as supposed to.
Old 07-05-2017, 12:05 PM
Colin G's Avatar
Should work. Hit side arrows so odometer is showing. Press the two buttons, (Call and OK) one slighter sooner than the other and hold for a few seconds. Scan down to Assyst Plus then hit OK. Scroll to completed service or whatever it is, select that and that should be it.
Old 07-05-2017, 12:18 PM
michail71's Avatar
2013 C250 Sport
Are you sure you are hitting call and not hang up? Are the wheel buttons working otherwise?
Last time I had the issue I was toggling to the trip menu like some of the videos say to do but my spedo was up. But most of those videos over complicate the process.
Key to first turn position
Make sure odometer shows on the dash.
Call then quickly OK, hold both down
Nothing else should matter beyond this.
Old 10-16-2018, 07:54 PM
dennish's Avatar
  1. Make sure the doors are closed. My difficulty was due to the door being open.
Old 10-17-2018, 06:17 AM
gamma300C's Avatar
2009 MB C300 Sport 4matic
That was my problem since the YouTube video with the Brit said the door being open wasn't a problem...it was with my C300.
Quick Reply: Service B reminder will not reset
