722.9 transmission leaking
Ive already done the recommended transmission service because I thought it was the pan gasket but its not. The breather valve is not leaking either.
Also, there is no sign of where the ATF is leaking from. Its spewing out from somewhere but impossible to tell from exactly where. It's pissing out so bad the underpart of the car is soaked. seems to only happen when I'm using the tip-tronic shift
Any helpful information will be appreciated.
Thanks in advance,
Mo
Thanks in advance,
Mo
I think what would be helpful other than telling us there is a leak is other info such as...
1) Where is the leak? I know you don't really know, but gravity only goes one way. Try and isolate the source of the leak by figuring out the high point and taking... (#2 below)
2) Photos?
3) Any symptoms that you feel outside of the leak in the tranny?
4) What did you do to cause the leak?
5) Has this happened before?
6) Any other relevant info?
I would suggest asking yourself this. If you told someone you were bleeding, and that's all they said, what other questions would you ask to figure out what the issue is?
Thanks in advance,
Mo
Are you sure it's transmission oil? fluids can travel far with the under carriage creating a sort of a wind tunnel under the car.
Place the car on jack stands and pay attention to the pump.
