Accelerator position sensor
The maximum value you can see on the attachment is when I pushed throttle button (in the floor) to the end.
Then I moved the accelerator a little bit lower just to touch the throttle button but do not press it and you can see it in the attachment.
Also accelerator pedal position E seems to be much lower but sync. with the D sensor.
Are these right and correct readings ?
ps. engine was turned off, I just tried to establish if my accelerator sensors are ok.
