sunroof problem
Old Jul 31, 2017 | 09:22 PM
biggie05's Avatar
2008 c300 luxury 4matic
sunroof problem
the sunroof will open but when it closes it opens back up
Old Aug 2, 2017 | 06:25 PM
Colin G's Avatar
2008 C-230 4Matic Sport
Try a sunroof reset.
Worked to fix my sunroof issue. The 2nd portion is the method that worked on my car.
Close all your car's doors.
Put the key to position II.
Don't start the car.
Open the sunroof all the way. It may require that you press the sunroof open switch several times.
Once you reach the fully open position, continue to HOLD the sunroof switch in the OPEN position until hear a click. If you don't hear the click make sure to hold the switch for up to 5 seconds.
Next, close the sunroof and again hold the switch for 5 seconds when you reach the closed position
Check if the problem has been fixed. If not, repeat steps 4 through 6.
You may also try these steps: (worked for my car)
With your key in position 1 or 2 and all doors closed, press the sunroof button to the tilt position and hold it for 5 seconds.
Push the button towards the rear seats and hold it for 5 seconds.
Push the button forward and hold again for 5 seconds.
Push it toward the bottom and hold it for 5 seconds.
Check if the sunroof is working properly again. Repeat steps 1-4 as needed.
