2011 C300 - One Click, Won't Start
My current issue is this: car won't start. There is enough battery to turn the lights on, radio, etc., but when I crank, I only get one click and that's it. Not multiple clicks. This is now the fourth time this has happened. What I've done the previous three times is jump start the car and then it works for a while. Say, the last time I did it, the car worked for two weeks with no problems. Then the issue crops up again.
I've checked fuses and everything seems fine. I've read that if the battery is low, it will still turn on the lights but won't send enough power to the starter to kick in. Maybe that's why I'm receiving one click?
I've crossed starter off the list because after I jump start the car, for a period of time it starts up just fine. The battery is about three years old.
I know there are a million issues it could be from a relay to ignition switch to cables, but what do the experts here say? Any best guesses/tips would be greatly appreciated.
I had the battery replaced, alternator charged and all was ok.
If your lights stay on and does not go dim. maybe something else, not sure if your newer model requires a higher voltage as min for start from the battery-?.
Technically, it could be the battery AND something else, but at least I can tell that the battery is the problem now.
Thanks for the help!
