Rear view camera
Old Sep 6, 2017 | 03:50 AM
ayman960's Avatar
C-class 350
Rear view camera
Hi
i have w204 without rear view camera, i purchased after market camera
every things going as per the plane except fakra cable
there were three green ports in the radio, so i need to know where i have to connect it ?/
regards
Old Sep 6, 2017 | 11:03 PM
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera.
It's been too long since I installed the camera. I only remember below based on my 2011 C300.
Fakra cable to me is a coaxial cable with SMB connector in a square shaped plastic housing. Don't remember which connector the fakra cable should plug into, only remember it is so close to another connector that I had to take the plastic housing out to plug the SMB connector in. No problem without the plastic housing, since the connector has a tight fit once plugged in.
I have never had any intermittent connection issues over more than six years.
I wish I could be more help. I am sure searching will pop up lots of help.
