Different load index
Old Oct 13, 2017 | 03:39 PM
Delhiite's Avatar
C300
Can I use tires with a load index of 94 for the two front tires and 91 for the two rear ones? Car's a 2010 C300 4Matic. The tire sizes for the front and rear are different. The tires are Goodyear Eagle Sport All Season.
Old Oct 13, 2017 | 04:06 PM
Cardfan91's Avatar
2014 C300
The load index is a rating of the tires ability to carry a certain load. The higher the number the more load it can carry. That shouldn't create any problems for you.
Old Oct 13, 2017 | 04:35 PM
Alfadude's Avatar
2012 C300 4Matic
The load index will not matter, but you want the circumfrence of the tires to be pretty much the same for both the front and rear axels. How much different in size are they?
Old Oct 14, 2017 | 06:33 AM
alecmascot's Avatar
W204 C220CDI 2011
You will find that the higher load-index tyre is much stiffer and will adversely affect the ride.
Old Oct 14, 2017 | 10:09 AM
superangrypenguin's Avatar
A car
It is not recommended that you have different load indexes due to the way the tires behave in emergency situations. My guess as to why this is is because of different rebound rates due to different sidewall stiffness.
Old Oct 15, 2017 | 01:01 AM
IGB's Avatar
IGB
'08 C300 MM Pano
A tire with a load index of 91 is designed to carry a load of 1019 lbs whereas a tire with a load index of 94 is designed to carry a load of 1102 lbs. A difference of 83 lbs is not even half of what your average passenger weighs. I don't see it making much of a difference as far as handling. In fact, I assume with a larger footprint on the (presumably) larger rear tires, the weight is distributed over a larger surface area of the tire which should help compensate for the higher flexibility of the 91 load rated tires.
