C300 2013 4MATIC, Needs Advice
Hello All,
At the advice of the dealer, changed the front passenger stock Conti tire (developed sidewall bubble) with a new tire. The dealer said replacing only a single tire would be safe since the rest of tires were slightly worn (all had thread depth of 7). I have read in this forum about potential damage to the 4MATIC transmission that could be caused by driving on unevenly worn tires.
a) Should I be worry about transmission damage in this situation?
b) if yes, then could under-inflating the new tire by several PSI, alleviate the potential damage to the 4MATIC transmission?
2007 civic Si 2004 Acura TL 2013 MB C350
rule is always replace tires in sets.... front 2 or rear 2 or all 4 if needed.... but like you said if slightly worn but still looks new..... i wouldn't worry about it.. 4MTIC on brother.... rest easy...
