Unplugged radiator fan
Old 10-18-2017, 01:12 AM
Widec200's Avatar
Mercedes Benz c200 1998
so the other day I was looking for a leak around my engine and for some reason I Disconected the radiator fan then reconnected it again whilest the battery was still intact, now here's the problem my car is starting to overheat during traffick and idle, I'm not sure if I messed with fans settings with the battery still connected or what?? Any info would be much appreciated.
cheers
Old 10-18-2017, 08:54 AM
mrbrannin1's Avatar
2007 civic Si 2004 Acura TL 2013 MB C350
hmmmmmmm i would say disconnect the battery for a few then reconnect.... see what happens.....
Old 10-18-2017, 09:46 AM
Alfadude's Avatar
2012 C300 4Matic
Are the fans working at all? If not, maybe you blew a fuse when you reconnected it. Or maybe double check the it is connected tightly.
Old 10-18-2017, 08:28 PM
Widec200's Avatar
Yup fan works when I turn heater on and fuses and relay good.
Old 10-18-2017, 08:29 PM
Widec200's Avatar
Will try battery method now
Old 10-20-2017, 12:44 AM
Widec200's Avatar
Battery method didn't work
Old 10-20-2017, 09:20 PM
keith100's Avatar
2008 c300
So which fan are you talking about here?
In your first post you mentioned the rad fan. Later you said the heater fan was OK, proving the fuses were OK.
These are different fans.
I'm pretty sure the rad fan will have different fuses/relays to the heater fan.
Maybe check the rad fan fuse/relay?
Good luck
