COMMAND KNOB - Not the usual issue
So I can "scroll" by turning the knob left and right but the issue I have is when you try to move the knob up/down or left/right. It seems like I can move within the audio menu when I move the knob up but cant seem to do anything when I try and move the knob left, right, or down.
You may be thinking that doesn't seem like a huge issue as long as I can scroll I should be able to navigate around most of the menus no problem. I was thinking the same thing until I test drove it and decided to adjust the Fade/Balance all the way to the front to test the speakers. I was able to move the fade to the front and now I am stuck. The Fade/Balance menu seems to be the ONLY one that the scroll function will not work in. Does anyone know of a way to adjust the fade back to center WITHOUT using the knob?
This site has been a major help in my research to find a nice vehicle and know what to look out for. Thanks in advanced for your help.
Chris
I realize it needs to be replaced and I will get to it soon but my question was more along the line of; is it possible to adjust the fade any other way?
As I was sitting in traffic this morning I decided to go through all the menus once again. I found the "system reset" button and decided to give it a shot. Since I have only had the car for a few days I didn't have much saved. After the system reset was performed my balance/fade was reset to be in the center. Since the comand knob still scrolls I can make my way through all the other menus no problem.
