left side rear lights not working
Old Nov 2, 2017 | 05:40 PM
Tris1041's Avatar
2010 c300
Exclamation left side rear lights not working
My left side (driver side) rear tail light, break light, reverse light, blinker and side marker arent working. I checked the fuse box inside the engine compartment and they all look fine. Could anybody help me out please. If it is a fuse, could you please tell me which one it may be. Its a 2010 C300 4matic sport. Thank you!!
Old Nov 3, 2017 | 02:10 AM
dol4er's Avatar
C204
I guess you don't have LED tail lights, so you might want to check the plastic board inside the tail light on which all bulbs are placed (not sure how it is called). It is very cheap and it gets easily burnt so it needs to be replaced. It may even cause fire if not changed on time.
Old Nov 3, 2017 | 08:33 AM
Tris1041's Avatar
2010 c300
a
Old Nov 3, 2017 | 10:20 AM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
Check here to see if your vehicle had the tail light recall taken care of.
http://www.mbusa.com/mercedes/recall
Enter your VIN # and it will tell you.
Old Jul 30, 2022 | 04:31 PM
Krajaram's Avatar
2012 c300 4matic
How did you solve it? I have the same problem on the rear passenger side, all lights complain not working but all the bulbs are good. I do see see a burnt connection in plastic holder of the lights.
