P0496
Old Jan 15, 2018 | 01:11 PM
Windsor Calm's Avatar
2012 C300
P0496
I have a 2012 C300 and the check engine light comes on every few days. My code reader says p0496, evaporative emission system high purge flow. Any ideas what could be causing it?
Old Jan 15, 2018 | 01:19 PM
2012 C300
I have checked and rechecked the gas cap and the code comes back. I did find one thread for this code and all of the folks who replaced their gas cap had the code return so looking for other solutions
Old Jan 29, 2018 | 09:34 AM
2012 C300
I pulled the evap purge valve out and tested it with a hand vacuum pump. At first, when I applied 25 bar of vacuum, it would hold but when I applied 15-17 bar of vacuum (which is what the engine vacuuum would be), it dropped to zero in about 10 seconds. So ordered a new valve from eEuroparts and will report back once it is installed.
Old Feb 4, 2018 | 09:49 AM
2012 C300
I installed the new purge valve yesterday and will now give it a week of drive cycles to see if the problem is cured. Will report back.
Old Mar 29, 2018 | 11:41 PM
2012 C300
The purge valve did it. Problem solved
2012 C300
<div style="text-align:left;">The purge valve did it. Problem solved</div>
