Has anyone had to replace their gas cap for a check engine light?
Old Jan 18, 2018 | 04:35 PM
Windsor Calm's Avatar
2012 C300
I am getting a code for an evap link and want to see if the gas cap is a common failure
Old Jan 18, 2018 | 05:36 PM
Alfadude's Avatar
2012 C300 4Matic
Post
I have tried that on couple other cars I owned and it never worked. Usually the gas cap I replaced looked almost new, even the seal. I think replacing it is almost like one of those old wives tales. But, on the other hand, it is cheap and easy to do.
Old Jan 19, 2018 | 12:51 PM
gamma300C's Avatar
2009 MB C300 Sport 4matic
When I have gotten an evap code on 2 other vehicles, the problem has been the evap purge valve failing in an open position..in one case a "whack" on the valve cured it for quite some time. With the purge valve off the car, you shouldn't be able to blow air through the two hose inlets....if you can, it is stuck open and will throw a code and cause the car to also throw a "lean at idle" CEL. Don't know where the valve is on my 09 C300...anybody got that info ? I have never had a gas cap seal fail.
