CEL, P0171, P0174, P2422
CEL is on and Autozone read gives P0171 (System Too Lean Bank 1), P0174 (System too Lean Bank 2), P2422 (Evaporative emission system vent valve stuck closed). Everything seems fine as far as how the car is running.
About 2 weeks ago after filling gas, my wife said the engine was turning but not starting and about 15 mins later it started.
Any ideas? thanks!
Any ideas? thanks!
If you have a w204 would take a look at the evap purge valve which is just to the driver's side of the driver's side air intake hose. if you do a Search on line you will see DIY's for it and how to check if stuck.
Thanks for the tip though, I will keep that in my back pocket if it ever comes back.
