help esl lock up ! wheels turned
Old Jan 30, 2018 | 08:14 AM
Lowufo's Avatar
2008 C300 4 matic
Hi All
I have the dreaded esl lock up on my 2008 c 300 Wheel is locked turned !!.I have the 4 bolts out for the steering column but the bolt at the bottom that on the shaft is clocked at the 10 o clocked position. looks almost impossible to get a socket on it.I know no other there way to get the esl out except removing the entire column . please any advise is welcome
Old Jan 30, 2018 | 04:07 PM
IGB's Avatar
IGB
'08 C300 MM Pano
Originally Posted by Lowufo
Hi All
I am not sure I understand what it is you are trying to do...
There are only 4 bolts that hold the steering column in place. Once those bolts are out (and the wheel lock wire harness is disconnected), you should be able to drop the steering column down and out...
In particular, this is the confusing part of your post:
... but the bolt at the bottom that on the shaft is clocked at the 10 o clocked position. looks almost impossible to get a socket on it.
But looking past that part, I m also curious to know what you plan on doing once you get the column out? Let us assume you are able to get the steering wheel unlocked somehow... unless you replace the faulty ESL, the start cycle will not proceed past the part where it checks if ESL I operable and if so, it continues with other checks, if not, then it terminates.
