Engine Management light
Old Feb 6, 2018 | 03:45 AM
Pvanzanden's Avatar
MB C180 CGI
Good day everyone,
My 2011 C180 CGI management light is on and had a diagnostic done to see what the issue could or might be.
Came up with 3 Codes:
P001762 The position of the exhaust camshaft (cylinder bank 1) is implausible relative to the position of the crankshaft. The signal comparison is faulty. CURRENT AND STORED
P233623 The knock limit of cylinder 1 was exceeded. No signal change. Voltage level is too loo CURRENT AND STORED
P233617 The know limit of cylinder 1 was exceeded. The limit value for electrical voltage has been exceeded. STORED
Position of exhaust camshaft -120.4 degrees (-112.9...-106.9)
What does this mean to me, I bit worried and concerned sounds not good .
Can someone please assist and explain what this all means and how it can be rectified or fixed.
Could timing chain jumped a tooth possibly? Can someone adjust that and move it back to original position?
Any advise will be appreciated
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
